Brand New fresh install of AutoCAD 2015 and it won't open. Returns the following message: The Application was unable to start correctly (0xc0000142).
Tried to install it on 3 various machines, all Windows 7, all 3 have the exact same message. Thus it's not computer related, it's either something with the build or a conflict with other software that is on all 3 of my PC's. (I.E. it's a pretty common software that it's conflicting with)
Dissappointing wanting to kick the tires on a new release and it won't even open! It's usually Christmas time for us Autodesk users, I just opened a present and found a lump of coal! ๐
Eric Bogenschutz
Solved by TravisNave. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
I have news for you, most of the programming is done in the USA.
I personally know programmers at Autodesk in Oregon, New England, and California.
Yes, there are programmers who reside in other countries as well, but since they have language packs for a dozen different languages, I think that is a requirement, don't you?
new problem,
I uninstalled 2015 then tried to reinstall
now during reinstall it tells me I have a newer version already installed - so I have no paths left to try
what do I do?
maybe 2016 will be a better year
If you look at the installation log file, you will probably find a Windows component that did not install, like the following:
2014/10/17:19:19:31 home HOME-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:19:19:31 home HOME-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
You can find information on that particular error, but the solution is to go to the Control Panel and uninstall (in this case) all of the C++ elements, then run the installer again. Typicallly the Autodesk software will reinstall the C++ elements, or if it is the .NET or DirectX elements, you can go to the Microsoft website and download them.
good advice, I'd missed that little check
thank you for sticking in here with me
as it turned out the 2015 SP2 update was removed
I deleted the C3D 2015 registry key (local machine) and right now the install is trying again
it just told me I have a newer version already installed
I spent the better part of the day reading this string and basically getting lost in the fun house. Finally solved the problem by uninstalling ilivid...some sort of downloading program that found its way onto my machine...fwiw.
Hi Sir,
I am from INDIA, recently I had installed AUTOCAD 2014 form AUTODESK website. Here in INDIA my INTERNET speed is 1 mpbs which is very slow, so I had to download AUTOCAD 2014 part by part. But when i am running the software it's not opening and all other application of the software is installed ( Tools and autocad recap etc.)
What should I do to rectify this problem ? Should I download it again.
Please help with the above is issue.
Product Information
Serial number: xxx-xxxxxxxx Product key: xxxxx
Please be aware that this is a public forum and posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
Hi @Anonymous,
Sorry to hear about the issue. Could you please provide us with your system specs and makes sure they meet the system requirements for AutoCAD 2014? Is AutoCAD displaying any messages when it does not open?
Hi @Anonymous
Here are the system requirements for AutoCAD 2014.
Can you give us more details on the installation failure? Did you get any error messages? Can you please post the installation log?
Thank you,
