Autocad fails on the above error, autocad architecture is alreday installed.
log file:-
2014/10/17:19:11:30 home HOME-PC === Setup started on HOME-PC by home ===
2014/10/17:19:11:30 home HOME-PC Path_Length: 157
2014/10/17:19:11:30 home HOME-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm
2014/10/17:19:11:30 home HOME-PC Launch
2014/10/17:19:11:30 home HOME-PC CommandLine
2014/10/17:19:11:30 home HOME-PC Current Directory C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp
2014/10/17:19:11:34 home HOME-PC === Setup ended ===
2014/10/17:19:11:32 home HOME-PC === Setup started on HOME-PC by home ===
2014/10/17:19:11:32 home HOME-PC Path_Length: 157
2014/10/17:19:11:32 home HOME-PC Current Directory C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp
2014/10/17:19:11:32 home HOME-PC Launch
2014/10/17:19:11:32 home HOME-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp\Setup\AcSetup.dll
2014/10/17:19:11:32 home HOME-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/17:19:11:34 home HOME-PC PageOpen LaunchDialog
2014/10/17:19:11:37 home HOME-PC PageOpen LicenseDialog
2014/10/17:19:13:02 home HOME-PC PageOpen ProductInfoDialog
2014/10/17:19:14:29 home HOME-PC PageOpen ProductSelectionDialog2
2014/10/17:19:14:37 home HOME-PC PageOpen FullProgressDialog
2014/10/17:19:14:38 home HOME-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\nigel\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/17:19:16:26 home HOME-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/17:19:16:26 home HOME-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\nigel\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/17:19:16:27 home HOME-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/17:19:16:27 home HOME-PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/17:19:16:35 home HOME-PC Install DirectX Runtime Succeeded
2014/10/17:19:16:35 home HOME-PC Installing Autodesk® AutoCAD® 2015: TRANSFORMS="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:19:17:53 home HOME-PC Install Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:19:17:53 home HOME-PC Installing AutoCAD® 2015 Language Pack: TRANSFORMS="C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp\_la1228.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:19:18:15 home HOME-PC Install AutoCAD® 2015 Language Pack Succeeded
2014/10/17:19:18:15 home HOME-PC Installing AutoCAD® 2015 Product Specific Pack: TRANSFORMS="C:\Users\nigel\AppData\Local\Temp\_AI3865.tmp\_la1228.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:19:18:23 home HOME-PC Install AutoCAD® 2015 Product Specific Pack Succeeded
2014/10/17:19:18:23 home HOME-PC Installing Autodesk® BIM 360™ Add-in for AutoCAD® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:19:19:19 home HOME-PC Install Autodesk® BIM 360™ Add-in for AutoCAD® 2015 Failed Installation aborted, Result=1603
2014/10/17:19:19:22 home HOME-PC Rollback AutoCAD® 2015 Product Specific Pack Succeeded
2014/10/17:19:19:24 home HOME-PC Rollback AutoCAD® 2015 Language Pack Succeeded
2014/10/17:19:19:31 home HOME-PC Rollback Autodesk® AutoCAD® 2015 Succeeded
2014/10/17:19:19:31 home HOME-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/17:19:19:31 home HOME-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:19:19:31 home HOME-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:19:19:32 home HOME-PC PageOpen InstallCompleteDialog
2014/10/17:19:19:48 home HOME-PC === Setup ended ===
