Windows 10 Professional?
Message 1 of 11
I have a MSI laptop computer with all the requirements to run Maya with Windows 10 home.
I downloaded both Maya 2016 and 2017 student version. The program was working fine, but has not been consistent.
Sometimes it loads fine, but other times it crashes on the startup- the program opens but the view-port does not load. Same goes for attempting to open a file.
I have tried re installing several times, restarting my machine, and I don't know why it's not loading properly.
I have heard that the professional version of Windows 10 is required. But I do not want to purchase that unless I know for sure that it works.
A friend of mine has been having lots of issues with his Maya on his Windows 10 pro PC as well... is Maya compatible?
Any advice/help would be much appreciated
Replies (10)
Message 2 of 11
Otto
Hello DeeJayBe and welcome to the Autodesk community!
It looks like you want information on installing a student license on more than one device. The following article(s) should help you resolve the problem:
Can I install the product on more than one computer?
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 11
TravisNave
Maya is compatible with Windows 10 and you do not need the Pro version.  Generally, if the application is crashing, it is almost certainly due to the video card/video driver combination.  What is your video card and driver?
Autodesk Forums:
Message 4 of 11
Thanks for the reply,
I'm not very computer savy, and was told this computer would run the program.
graphic card: NVIDIA GTX960M
Processor: Intel Core i7-5700HQ CPU @ 2.70GHz  (intel HD Graphics 5600)
12GB ram 64 bit
Message 5 of 11
TravisNave
While I cannot find a supported driver for that card, you might have luck installing this latest WHQL driver from NVidia:
http://www.nvidia.com/download/driverResults.aspx/111030/en-us
Perform a clean install if it asks.
Good Luck!
Autodesk Forums:
Message 6 of 11
tried this, updated the card to version 375.95 with a clean install.
It still will not launch Maya. I see that the 960 card is not on the Maya certified list. But the 780 or 980 is. Do I have the wrong graphics card? Do I need a different machine?
-Darynn
Message 7 of 11
TravisNave
Maybe?  When it comes to graphic intensive applications like Maya, the approved list actually has much more of an impact, than say, AutoCAD would.
Autodesk Forums:
Message 8 of 11
And upgrading Windows to Professional will not make a difference?
Message 9 of 11
TravisNave
I honestly can't imagine that it will.  Though the requirements state Pro version of Windows 10, the only differences in the OS are generally IT related and not software related.  Unless you plan on using more than 128GB of RAM, join a domain, or use Hyper-V, there is virtually no difference.
Autodesk Forums:
Message 10 of 11
Okay, I am not sure what I will do now. My friend has the exact same computer and card and it works just fine. Mine must be corrupt or something.
Appreciate the help.
-Darynn
Message 11 of 11
TravisNave
I hear ya.  I usually blast about 30 laptops simultaneously from one preconfigured image.  Sometimes there will be 1 or 2 of them that just won't work even though they are supposed to be identical.
Autodesk Forums:
