TrueView Crashes on startup
barry9UDQ6
barry9UDQ6
Hi Guys, all of a sudden I can't open TrueView.
I tried a repair install, but no luck.
TravisNave
These are almost always .NET Framework issues.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
barry9UDQ6
Thanks Travis
My solidworks is also crashing on startup, with the event log giving a .net error. So looks like you are spot on!
My ssd has become very messy over the last few years, so I have gone full retard and done a clean install of windows..
Let's see what happens.
