Revit Install
Revit Install
Revit Install
Hey. Trying to install Revit on my windows 7 pc. I have spent some time scanning the forum for fixes, and have tried about (i think) everything.
Attached is my latest log file.  Mostly result 1619, sometimes 1603. I'v uninstalled all the C++ files and the .net framework. Firewall off, virus off, run as administrator, tried a new user, adjusted router settings. Suprised my computer still turns on...
THANK YOU!
TravisNave
Install	Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)	Failed	Installation aborted, Result=1603
Your error is shown above.
I would start here:
http://upandready.typepad.com/up_and_ready/2012/09/error-1603-microsoft-visual-c-2005-sp1-redistribu...
If that doesn't fix it, see my signature link on how to modify your setup.ini file to ignore this error during the check for prerequisites.
Good Luck!
Autodesk Forums:
I'm not sure what exactly did it. I worked all the way thru up to modifing the ini file. But my download was corrupt or never finished. So i attempted the download again, which went fine. Thought I'd try installing w/o modifying the ini, and success.
Thanks!
