- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Everyone,
I wanted to point out that I get a lot of requests asking if emails about Autodesk Audits are real. I want inform you that they are indeed real. If you get an email that looks like the following example, you should comply:
Subject: [Request Notification] Your Autodesk Software Review
Dear Autodesk Customer,
As part of Autodesk's on-going Software Asset Management Program, your company has been selected to undergo a required software compliance audit. This process will help ensure your organization's installation and use of Autodesk products and services is compliant with applicable licensing agreements,
Please perform an inventory of your deployed Autodesk software and provide the required information in the Autodesk Software License Review Portal within the next 15 days.
The portal is located at https://software-review.autodesk.com/. Your company's unique registration code is 12345A-12BDC3-E123456789
A user Guide, FAQs, and other resources are available on the portal to guide your company through this process.
If you have any issues with the portal, please contact an Autodesk Software Asset Management Consultant at 1-833-588-9571.
Autodesk would like to thank you for your continued business. We value our partnership and believe that our joint attention to software compliance will strengthen this relationship going forward.
Yours Sincerely,
The Autodesk Software Management Team
www.autodesk.com
Please do not reply to this email. Replies to this email will not be responded to or read.
CONFIDENTIALITY NOTICE
This email transmission is intended only for the use of the individual or entity named above and may contain information that is confidential, privileged and exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or use of any of the information contained in this transmission is strictly PROHIBITED. If you have received this transmission in error, please destroy the original transmission and its attachments without reading or saving in any manner. Thank you.
Autodesk will audit you based on the Software License Agreement. You should familiarize yourself with the Software License Agreement of the product line that you are currently using. I recommend that you do a self-audit to ensure your compliance before you receive this notice. If you have any questions, you may wish to contact your VAR to see if they offer a Software Asset Management service to ensure that you are within compliance before a potential audit. Once you have received this email, however, you must comply within the specified timeframe and you will no longer be eligible for a SAM audit internally by your VAR.
For more information about license compliance or to report piracy, please see this link.
Travis Nave
