Here's the Log: and a screen shot of an error. to be clear, this is now a different issue than what i had been experienceing before.
2016/5/7:16:24:40 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/7:16:24:40 andrew LEORIC Path_Length: 153
2016/5/7:16:24:40 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI5475.tmp
2016/5/7:16:24:40 andrew LEORIC Launch
2016/5/7:16:24:40 andrew LEORIC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2016/5/7:16:24:40 andrew LEORIC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2016/5/7:16:24:41 andrew LEORIC PageOpen LaunchDialog
2016/5/7:16:28:27 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:28:27 andrew LEORIC PageOpen ProductInfoDialog
2016/5/7:16:28:27 andrew LEORIC PageOpen ProductSelectionDialog2
2016/5/7:16:37:38 andrew LEORIC === Setup ended ===
2016/5/7:16:40:46 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/7:16:40:46 andrew LEORIC Path_Length: 153
2016/5/7:16:40:46 andrew LEORIC Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/5/7:16:40:46 andrew LEORIC Launch
2016/5/7:16:40:46 andrew LEORIC CommandLine /PK 657H1 /SN 900-21282123 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2016/5/7:16:40:46 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI1485.tmp
2016/5/7:16:40:47 andrew LEORIC === Setup ended ===
2016/5/7:16:40:46 andrew LEORIC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2016/5/7:16:40:46 andrew LEORIC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2016/5/7:16:40:47 andrew LEORIC PageOpen LaunchDialog
2016/5/7:16:40:50 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:40:50 andrew LEORIC PageOpen ProductSelectionDialog2
2016/5/7:16:41:02 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:41:02 andrew LEORIC PageOpen LaunchDialog
2016/5/7:16:41:04 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:41:04 andrew LEORIC PageOpen ProductInfoDialog
2016/5/7:16:41:04 andrew LEORIC PageOpen ProductSelectionDialog2
2016/5/7:16:49:23 andrew LEORIC PageOpen ProductInfoDialog
2016/5/7:16:49:23 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:49:23 andrew LEORIC PageOpen LaunchDialog
2016/5/7:16:51:17 andrew LEORIC === Setup ended ===
2016/5/7:16:51:51 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/7:16:51:51 andrew LEORIC Path_Length: 153
2016/5/7:16:51:51 andrew LEORIC Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/5/7:16:51:51 andrew LEORIC Launch
2016/5/7:16:51:51 andrew LEORIC CommandLine /PK 657H1 /SN 900-21282123 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2016/5/7:16:51:51 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI3CDD.tmp
2016/5/7:16:51:52 andrew LEORIC === Setup ended ===
2016/5/7:16:51:52 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/7:16:51:52 andrew LEORIC Path_Length: 153
2016/5/7:16:51:52 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI3CDD.tmp
2016/5/7:16:51:52 andrew LEORIC Launch
2016/5/7:16:51:52 andrew LEORIC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2016/5/7:16:51:52 andrew LEORIC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2016/5/7:16:51:52 andrew LEORIC PageOpen LaunchDialog
2016/5/7:16:51:55 andrew LEORIC PageOpen LicenseDialog
2016/5/7:16:51:55 andrew LEORIC PageOpen ProductInfoDialog
2016/5/7:16:51:55 andrew LEORIC PageOpen ProductSelectionDialog2
2016/5/7:16:52:06 andrew LEORIC === Setup ended ===
2016/5/9:16:00:53 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/9:16:00:53 andrew LEORIC Path_Length: 153
2016/5/9:16:00:53 andrew LEORIC Current Directory C:\Autodesk\Autodesk_Maya_2016_wi_en-US
2016/5/9:16:00:53 andrew LEORIC Launch
2016/5/9:16:00:53 andrew LEORIC CommandLine /PK 657H1 /SN 900-21282123 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/Autodesk_Maya_2016_wi_en-US_Setup.exe?dummy=0"
2016/5/9:16:00:53 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI49B8.tmp
2016/5/9:16:00:56 andrew LEORIC === Setup ended ===
2016/5/9:16:00:54 andrew LEORIC === Setup started on LEORIC by andrew ===
2016/5/9:16:00:54 andrew LEORIC Path_Length: 153
2016/5/9:16:00:54 andrew LEORIC Current Directory C:\Users\andrew\AppData\Local\Temp\_AI49B8.tmp
2016/5/9:16:00:54 andrew LEORIC Launch
2016/5/9:16:00:54 andrew LEORIC Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2016/5/9:16:00:54 andrew LEORIC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUPMAR...
2016/5/9:16:00:54 andrew LEORIC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2016/5/9:16:00:56 andrew LEORIC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/SETUP_x6...
2016/5/9:16:00:56 andrew LEORIC PageOpen LaunchDialog
2016/5/9:16:01:01 andrew LEORIC PageOpen LicenseDialog
2016/5/9:16:01:01 andrew LEORIC PageOpen ProductInfoDialog
2016/5/9:16:01:01 andrew LEORIC PageOpen ProductSelectionDialog2
2016/5/9:16:01:14 andrew LEORIC PageOpen FullProgressDialog
2016/5/9:16:01:14 andrew LEORIC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2016/5/9:16:01:14 andrew LEORIC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/STARTMAR...
2016/5/9:16:01:14 andrew LEORIC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2016/5/9:16:01:15 andrew LEORIC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2016/5/9:16:01:15 andrew LEORIC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/5/9:16:01:16 andrew LEORIC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/5/9:16:01:17 andrew LEORIC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2016/5/9:16:01:17 andrew LEORIC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/VCREDIST...
2016/5/9:16:01:17 andrew LEORIC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/5/9:16:01:18 andrew LEORIC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/5/9:16:01:18 andrew LEORIC Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2016/5/9:16:01:19 andrew LEORIC Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/DIRECTX....
2016/5/9:16:01:19 andrew LEORIC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/5/9:16:01:22 andrew LEORIC Install DirectX® Runtime Succeeded
2016/5/9:16:01:22 andrew LEORIC Download Play MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2016/5/9:16:03:46 andrew LEORIC Download Complete MAYA http://edutrial.autodesk.com/NET16SWDLD/2016/MAYA/WI/{C60E82DC-CEAE-422A-9676-A6694F88E736}/MAYA_en-...
2016/5/9:16:03:48 andrew LEORIC Installing Autodesk® Maya® 2016: TRANSFORMS="C:\Users\andrew\AppData\Local\Temp\_AI49B8.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2016" INSTALLDIR="C:\Program Files\Autodesk\Maya2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/9:16:16:41 andrew LEORIC Install Autodesk® Maya® 2016 Failed Installation aborted, Result=1603
2016/5/9:16:16:41 andrew LEORIC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/5/9:16:16:41 andrew LEORIC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/5/9:16:16:41 andrew LEORIC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
