LMTOOLS not pulling correct ethernet address for system settings
Message 1 of 11
The LMTOOLS is not pulling the correct ethernet MAC on my server, it is displaying ffffffff
Replies (10)
Message 2 of 11
Darin.Green
That can be misleading which could be caused by NIC Teaming... Are users able to get a license from the license manager?
If this information was helpful, please consider using the Accept Solution
Message 3 of 11
TravisNave
This happens sometimes if you have a virtual machine or if you are running two NICs that are teamed.  What version is your LMTOOLS?
What I can tell you is this... it doesn't really matter if it shows ffffffffffff as long as the actual MAC of the system matches the .LIC file.
If you open a CMD prompt and type
GETMAC
It will give you the MAC address(es) of the machine.
Keep me posted on this.
Autodesk Forums:
Message 4 of 11
The Machine uses 2 network cards and has been running fine. I had switched the License file to point to the new one for Civil3D 2016 to test for for deployment and it worked, switched back after the test and everything was good.... then I tried to switch again and now nothing works... I have updated to the new version nlm11.13.1.2_ipv4_ipv6_win64 before I started testing the deployment of Civil3D2016.
Message 5 of 11
TravisNave
Make sure you stop the server and that the lmgrd.exe and adskflex.exe processes are not still resident in Task Manager.  Start the license service again from LMTOOLS and post your Status Enquriy/Debug log file if you still have problems.  This is definitely fixable, so don't sweat it.  🙂
Autodesk Forums:
Message 6 of 11
Here is what I get
Status
Flexible License Manager status on Thu 5/12/2016 14:11
[Detecting lmgrd processes...]
License server status: @WaterGIS
License file(s) on WaterGIS: D:\NASShare\AutoCad\Autodesk License Manager\CIV3D2016enlicense.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: WaterGIS
License path: @WaterGIS;
FlexNet Licensing error:-15,570
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Message 7 of 11
DarrenP
it looks like a port conflict
try changing the port
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-change-the-assign...
DarrenP
Message 8 of 11
TravisNave
Does your MAC address from the command prompt match your .LIC file?
Autodesk Forums:
Message 9 of 11
Yes the MAC adress for the ethernet match the lic file but in the LMTOOLS it is still ffffffff
Message 10 of 11
I changed the ports but still not there...
Message 11 of 11
TravisNave
Yeah, don't worry about what LMTOOLS shows.  You have a debug.log file to show?
I suspect we might be able to resolve this with version 11.7.
Autodesk Forums:
