License reservation not working
juan.c.ayala
Message 1 of 15
juan.c.ayala
Our company runs 2 license severs for Autodesk products. One server holds the licenses for AutoCAD and Raster Design, while our second server holds licenses for infrastructure design suite 2014. The issue we are having is that at the time that we packaged AutoCAD, we had one license server, well call it server 1. We recently built a new license server (server 2). Server 2 now contains all of the AutoCAD licenses and server 1 only holds 6 licenses or Infrastructure design Suite 2014. We have been redirecting AutoCAD users to the new server via a script file that updates the registry entry. The problem is that this update is only applied if users launch the application correctly, from our Novell application launcher. 20% for our users don't do that, they just double click DWG files. This totals about 80 users. So 80 users are connecting to server 1 tying up the Infrastructure design Suite 2014 licenses. Users are complaining that they cannot use Civil 3D because a license cannot be found. I decided to reserve licenses for our Civil users and entered the following into our OPT file.
RESERVE 1 86123IDSP_2014_0F USER 0P5388
RESERVE 1 86123IDSP_2014_0F USER 0P1134
RESERVE 1 86123IDSP_2014_0F USER 0N4786
RESERVE 1 86123IDSP_2014_0F USER 0P5384
RESERVE 1 86123IDSP_2014_0F USER 0T4984
When I restart the Server I get this message to confirm license reservation.
15:52:10 (adskflex) RESERVING 1 86123IDSP_2014_0F/1B12 3B00 E6D5 DB33 license for USER 0P5388
15:52:10 (adskflex) RESERVING 1 86123IDSP_2014_0F/1B12 3B00 E6D5 DB33 license for USER 0P1134
15:52:10 (adskflex) RESERVING 1 86123IDSP_2014_0F/1B12 3B00 E6D5 DB33 license for USER 0N4786
15:52:10 (adskflex) RESERVING 1 86123IDSP_2014_0F/1B12 3B00 E6D5 DB33 license for USER 0P5384
15:52:10 (adskflex) RESERVING 1 86123IDSP_2014_0F/1B12 3B00 E6D5 DB33 license for USER 0T4984
5 out of the 6 licenses are reserved, but when any of the users listed above try to connect, they get a denial
15:52:19 (adskflex) DENIED: "86123IDSP_2014_0F" 0P5388@ZL8740  (Licensed number of users already reached. (-4,342:10054 ""))
I did notice that the denial includes the users PC number "@ZL8740" should I be including this as well? Should it read
RESERVE 1 86123IDSP_2014_0F USER 0P5388@ZL8740.
Replies (14)
Message 2 of 15
TravisNave
Your options file is a little inefficient.  You should set up a GROUP and put the users in the group, then set a RESERVE on the GROUP.  And you absolutely need to have GROUPCASEINSENSITIVE ON set or it won't work because of case-sensitivity.
For eveything you could possibly want to know about the adskflex.opt Options file for FlexLM, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Managing-the-adskflex-opt-Options-File/td-p/307...
Good Luck!
Autodesk Forums:
Message 3 of 15
This actually doesn't answer the question at all. I've encountered same problem and putting users in a group didn't solve it at all.
Users of 86718CIV3D_2017_0F:  (Total of 53 licenses issued;  Total of 18 licenses in use)
  "86718CIV3D_2017_0F" v1.000, vendor: adskflex, expiry: 28-feb-2019
  floating license
    soverchenkomd E-70-0889 E-70-0889 (v1.0) (vpp-lic09/27000 301), start Mon 11/20 16:52  (linger: 13502060 / 13508760)
    vasiukovmm E-70-0275 E-70-0275 (v1.0) (vpp-lic09/27000 801), start Mon 11/20 16:53
    KORMNOVAER C-10-2042 C-10-2042 (v1.0) (vpp-lic09/27000 7601), start Mon 11/20 16:53
    ivanovda E-70-0582 E-70-0582 (v1.0) (vpp-lic09/27000 8201), start Mon 11/20 16:53
    ShemyakinAS E-70-0007 E-70-0007 (v1.0) (vpp-lic09/27000 10601), start Mon 11/20 16:53
	13 RESERVATIONs for GROUP Civil (vpp-lic09/27000)
Some of these users are in Civil group, still they don't use reserved licenses and borrow new ones.
GROUP Civil soverchenkomd vasiukovmm petrovas Seleznevaa KORMNOVAER ivanovda KaradzhayanRA ShemyakinAS ChuchkalovaAV soninarv karmilinami GorenkoSV KashirskayaAE
RESERVE 13 86718CIV3D_2017_0F GROUP Civil
I just don't get it. How can I reserve some licenses for these users?
Message 4 of 15
Mark.Lancaster
@Anonymous
Your option file syntax is off.  You need to be doing this..
Mark Lancaster
Message 5 of 15
TravisNave
Explain the issue you are having exactly and please also show your debug.log file that shows that your adskflex.opt options file is in use.
Autodesk Forums:
Message 6 of 15
I've posted it on another thread already but I will post it here and all my further posts will be here.
I've got some AECCOL licenses for Civil 3D users, but my other users happen to borrow those licenses for Revit or AutoCAD. So i've decided to reserve some Civil licenses for Civil users so they can launch Civil at any time.
So I've created adskflex.opt file just next to my lic file. It looks like this:
RESERVE 13 86815AECCOL_T_F GROUP Civil
Those users on the list are Civil users and I want them to access Civil at any time. After time I went to check on the licenses and I saw that Civil users don't take their reserved licenses. Instead they take new ones. You can see it here:
floating license
As you can see, users soverchenkomd, KORMNOVAER, ivanovda, ShemyakinAS got some brand new Civil licenses even though they have 13 reserved ones. This leads to 18 license usage instead of 14.
I've tried to reserve not Civil but whole AECCOL to them and got same result. Here is my log file showing that opt file is correctly parsed:
20:23:28 (adskflex) Rereading options file...
20:23:28 (adskflex) RESERVING 13 86718CIV3D_2017_0F/0B98 1307 3FEE CEDA licenses for USER_GROUP Civil
20:23:28 (adskflex) (@adskflex-SLOG@) ===============================================
What should I do next? Why reservation doesn't work?
Message 7 of 15
I've did it like on the picture. Nothing changed.
Message 8 of 15
juan.c.ayala
I am the original poster of this issue. The problem was that the user names were case sensitive, The issue has been resolved.
Message 9 of 15
Sadly this doesn't help too as usernames are totally the same including case :(.
I could use setting usernames case insensitive though. Is there a way to do so?
I see. I have GROUPCASEINSENSITIVE ON so this is not the issue.
Message 10 of 15
natasha.l
Hello @Anonymous,
Do you have access to Enterprise Priority Support? You can check your support level by accessing your account & following the steps in this article.
Message 11 of 15
juan.c.ayala
You are reserving a different feature for the Group Civil. Look at the feature name that shows up when users connect to Civil and the actual feature name specified in your reservation string.
Message 12 of 15
My bad, I was playing around with different settings and confused you by sending it here. Actually there is 86718CIV3D_2017_0F there right now. But it is the same because AECCOL contains this Civil license.
And yes, I have advanced support, but I never got to set up a call because all Russian language slots are always busy and I'm not sure if I can go to English support.
Message 13 of 15
Mark.Lancaster
@Anonymous
When did you generate the license aspect for Collection?  Did you regenerate the entire license or did you add the collection information to your existing license?
Mark Lancaster
Message 14 of 15
I'm sorry, I don't really understand what are you talking about. I'm not the one who set up this server. Can I check this information in LIC file or somewhere else?
Message 15 of 15
SUDDENLY as night passed it started working as intended. Problem is solved, i guess...
