Installing AutoCAD Core Console (only)
soonhui
Advisor Advisor
soonhui
Is it possible to install AutoCAD Core Console only and not the full version of AutoCAD?
I just need to keep older versions of AutoCAD in core console form so that I can run unit tests regarding my plugin in the older versions of AutoCAD.
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
TravisNave
It is not possible to install just the core console portion of AutoCAD, even if that is all you plan to use.  Sorry about that.  It still requires the fully licensed version of the product.  You can have multiple releases of AutoCAD on the same system, however.
Autodesk Forums:
