Installation problems
hello  everyone,
I  installed  Naviswork2016  for  many  times, it   always  says  that   the   operation  system   is  not   supported. What  can  i  do ?
Thanks,  anyway!
camilo.lemos
Hi @Anonymous and welcome to the Autodesk Community!
The first step is to check whether your computer meets all the system requirements for Navisworks 2016. You can find the system requirements here.
Also, Navisworks 2016 requires a 64-bit system. Make sure that your computer runs a 64-bit environment by following these steps.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Camilo Lemos
TravisNave
If you are using Windows 7, you must be SP1 first.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you very very much!!!
