Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Installation impossible, remains stuck at 98%
sylviadonze
Observer Observer
sylviadonze
Observer
Observer
Hello there, Pardon my english... i'm french.
I buy Autocad 2022 for my Mac. An old one, He run under Catalina 10.15.7. It should work correctly.
The installation remains stuck at 98% and when i go into the activity monitor i can read that the SETUP doesn't respond.
I have already remove all the trace of autodesk files before trying again but... the problem is still here.
Is somebody can help me ?
TravisNave
Sometimes it just takes an extraordinary amount of time to finish.  Other users have simply let it run overnight to find that it finally finished when they checked on it the next morning.  My recommendation is just to be patient and let it finish.
Good Luck!
Autodesk Forums:
sylviadonze
Observer
Observer
Thanks Travis.
I'm gonna let it run that night and see what happen.
sylviadonze
Observer
Observer
I let it run all night but he installation failed. The firewall is disabled, all incoming permissions regarding autodesk are ok. I don’t know what to do anymore.
I removed any Autodesk file before restarting the installation, but nothing to do. The only clue I have is in the activity monitor, SETUP does not respond...
So, somebody to help 🙂 ?
Community Visitor
Community Visitor
I found a fix, When the install is stuck at 98, go to the task manager and right click on the intstaller. one youve done go to security, press edit, and allow full access. after i did that my install was fixed.
skerlin5VN2Y
Community Visitor
Community Visitor
This worked for me, thank you!
