Installation complete,some products failed to install.error 1603
Hello! Autodesk community.
1) I am trying to install 3ds max 2016 student version on my pc which is only 5 months old.
2) At the end of the installation i get a message saying installation complete ,some products failed to install.
3) I tried many times with most of the tricks found on the net some i did not understand but it did not work !.
4) I don t understand what is happening and what is actually causing the problem.
5) Please some one help me how to get rid of it, its very irritating! By the way i have used 3ds max 2010 on my pc it works.
6) please solve my problem,all my pc specs, install and setup log file, pics etc hve been attached. Thankyou.
PC specs:
CPU: intel core i5 4590.
GPU: asus Nvidia Geforce GTX 960 4GB memory.
RAM: 8GB.
PSU: 500watts.
MOB: asus Z97 pro Gamer motherboard.
OS: Windows 7 ultimate. {not interested to update to windows 10}
Otto
Hello bruce098
It looks like you’re seeing Error 1603. Error 1603 is a generic error generated by the Microsoft Windows Installer (MSI) when a problem occurred during the installation of your Autodesk product. The following article(s) should help you resolve the problem:
Error 1603 during installation of Autodesk software
Errors during AutoCAD software installation
Here is some general information about installation, licensing and downloading Autodesk software:
AutoCAD 2012 installation fails on machine with NET 4.5
Previous Versions of Autodesk Software
Installation, Activation and Licensing
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
It appears ifs failing on the C++ 2012 Redistrubtion interface.  Meaning most likely you have a newer version of the application which the install doesn't like.  Go into WIndows/Control Panel/Program featiures/Add&remove programs and remove it.  Then try the installation again.  Also make sure to remove the 332B and 64B version of it.
Mark Lancaster
I removed the prerequisite error by removing the dotnet and vcredist and also the diretx runtime from the setup.ini as told by travisnave and deleted the ms cc+2012 and reinstalled it manually,it still did not work.so now what is causing the problem i want to know the specific thing that is causing the problem and the solution plz .
{Bellow i have provided the new setup.log,install.log and setup.ini which i edited}.
TravisNave
Your Max is actually failing for a non-descript reason.  It is not a prereq in this case.  It is actually failing on the 3DS Max portion itself.  You might need to find the Max log in the %TEMP% folder, but even that might not necessarily show the reason.
Where did you obtain the install files?  And are you installing with local admin rights, UAC off, and anti-virus disabled?
Autodesk Forums:
No attually there was a error in the prerequisite , In the 4th post i hve provided the edited files .I think you did not check the first posts attachements of this thread that contains the file before editting ,in that you can clearly see that the prerequisite are failing.and i had closed all the anti virus softwares and fire wall etc.i had edited the setup.ini file like you had told in another thread.so now whats the problem?
hello! anybody there.
