FlexNet Licensing error:-15,570
it.saejakarta
it.saejakarta
I am having this issue where the LMTOOLS Utility cannot Stop, Force stop or Reread the licence file.
Despite the service running and appearing in the task manager I still receive this message when doing a Status Enquiry
Status
Flexible License Manager status on Wed 3/16/2016 16:20
[Detecting lmgrd processes...]
License server status: @SAE-ANI-HUB
    License file(s) on SAE-ANI-HUB: C:\Autodesk\Network Licenses\ENCSU2015enlicense Creative Suit 2015 16-03-2016.lic:
lmgrd is not running: Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Server name:   SAE-ANI-HUB
License path:  @SAE-ANI-HUB;
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
I have run a TCP/IP reset and A Winsock reset./
Any suggestions would be greatly appreciated?
Window 10 Home 64bit
Otto
Hello it.saejakarta
It looks like you are seeing "Error 15" when registering and activating software or using the Portable License Utility. The following article(s) should help you resolve the problem:
Port numbers for single server FLEXlm setup
Problems registering and activating software or using the Portable License Utility
Checklist for troubleshooting Activation and Licensing issues
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
it.saejakarta
All of these auto response settings are set correct and are open on network security.
TravisNave
If the LMTOOLS is running on the same machine that you are trying to use the product on, this is almost certainly an IPv6 error.
Ping yourself.  Bet you don't get a IPv4 address.  That's why you get the -15, since the machine cannot connect to itself over IPv6 local loopback.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
It's a little harder to fix on Windows 10, but it is still manageable.
Good Luck!
Autodesk Forums:
it.saejakarta
Found the solution myself.
It was an issue with the latest ZoneAlarm Extreme Security version  14.1.048.000
It was blocking all communication with lmgrd.exe. Setting the ports open, disabling the ZoneAlarm with turning off the 'program' and 'firewall' control or shutting it down completely wouldn't allow any communication.
Ended up un-installing it and switching antivirus/firewall software.
In regards to the previos sugested solution.
Network enviroment isn't enabled for IPV6 in this case.
A ping to the machine from itself was working on IPv4. And all other machines were able to ping and connect to the servers shared folders no problem.
Thnak you for the help anyway.
