Borrow license message
corneliavoicu
Message 1 of 12
corneliavoicu
It is possible to disable the borrow license message that appears each time I run AutoCAD after I borrowed the license?
Replies (11)
Message 2 of 12
hashim.mundol
I don't find any documented method for this, may be the community has found some tricks
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 12
TravisNave
There is no way to do this.  Sorry.
Autodesk Forums:
Message 4 of 12
corneliavoicu
OK
Thank you all for your answers!
Message 5 of 12
Get hold of a copy of AutoHotKey & install it
http://www.autohotkey.com/
Create the following script and save it as LicenseBorrowed.ahk
Loop
  IfWinExist License Borrowed
      WinActivate
      Send Keys {Enter}
  Sleep 1000
Double-click the AHK file to start the script. Run AutoCAD & when the "License borrowed" window pops up, it will disappear within a second.
You can compile the script to an executable with AHK, and put a link to the EXE in your Startup group to make it run all the time
Nick
Message 6 of 12
Many thanks for this example Smiley Happy
Is there also a possibility to close the info balloon bottom right witch comes after?
regards René
Message 7 of 12
DarrenP
there is this one: http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3aLicense-Bo...
DarrenP
Message 8 of 12
TravisNave
Nope. Been a wishlist item forever.
Autodesk Forums:
Message 9 of 12
TravisNave
Jimmy is so clever!
Autodesk Forums:
Message 10 of 12
many thanks for all the Feedacks!
sadly this named solution is not working in all cases Smiley Sad
...and for the first message box this is not working!
For the Balloon-Message it works on ACAD 2014 german, but it does not work in ACAD 2013 german...
I had the hope to find a version-independent solution for that.
soon as i find the gap, of corse i will post it here
Message 11 of 12
peterfnet
Observer
Observer
in response to DarrenP >>>there is this one: http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3aLicense-Bo... It works, but it is a little problematic. I think the plug-in just looks for open windows/processes that have keywords like borrow, licence, etc. I had a Chrome window open that had this window and maybe the AutoDesk store for the plug-in. Since the window/tab had the keyword, it closed my browser. I couldn't reopen it until I shut down the plug-in.
Message 12 of 12
Is there a follow up to this?  It is preventing my batch files from running, which is not cool Autocad.  Your breaking normal functionality.
