Autodesk Building Design Suite Ultimate 2015 Installation Error
Could not install Autodesk Building Design Suite Ultimate 2015. Error log file is attached.
Mark.Lancaster
@Anonymous
Welcome to the community...
Review the 1603 error link in my signature and I also recommend that you use the Autodesk Virtual Agent to download and install your software
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
TravisNave
Install	Autodesk® AutoCAD® 2015	Failed	Installation aborted, Result=1603
Do you already have any other Vanilla or vertical of AutoCAD installed?  Like Mechanical, Architecture, or Electrical, for example?  You might also check that you are not installing with an update included in the installer.
Might check my thread here:
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-...
As always, install with local admin rights, UAC off, and anti-virus disabled.
Good Luck!
Autodesk Forums:
Hi Mark,
I followed the steps you suggested, the extraction completed and then this message appeared. I tried it twice, same thing happened. Any thoughts?
