Autocad reinstallation problem
Hi all recently i uninstalled the autocad 2016 from my lap top as it was getting hanged at start up ( precisely at checking liscence during start up). I uninstalled autodesk recap2016, a360 desktop and extracted all the files from same old folder and reinstalled. Now only autodesktop revap2016 and a360 desktop are getting reinstalled what shall i do.
Darin.Green
It would be best to post the installation log file within you %temp% directory so we can see what's going on during the installation process.
Download the software from the Autodesk Virtual Agent
  • Once there, use Download Links and navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Darin.Green
Are you still having trouble with reinstalling the software onto your machine?
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-pr...
If you still have issues, post the installation log as Darin mentioned from the %TEMP% folder or the link in the failure summary screen.
Autodesk Forums:
