AutoCAD installation failing
Regardless of the version, 2012-2015 of all autodesk programs refuse to download.
A popup comes up after about 10 seconds and says it failed.
This is the log:
I disabled my anti-virus and firewall
The actual log:
TravisNave
Install	Microsoft Visual C++ 2010 Redistributable (x86)	Failed	Installation aborted, Result=1603
 Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Autodesk Forums:
Uh... my error log doesn't say any of that.
TravisNave
This is copied directly from your installation log:
 It is failing on the prerequisite install.  I provided multiple solutions for this exact problem in the links of my original reply.
Thanks.
Autodesk Forums:
