Hi @Karsten.Saenger:
I did exactly what the “CES226263: A Match Made in Coordinates: Bringing Revit, Civil 3D, and InfraWorks Together at Last”.
It was very helpfull, but I still have a problem. First of all, I am working in meters. So, I did everything that the class handout says, and worked well until I wanted to import into Infraworks.
In Civil 3D, as the class says, I could link the revit model (see image below).
Revit model integrated into Civil 3D
The Revit model that you see in Civil 3D (image above) is the FBX that I exported from Naviswork Manage (see image below):
Exporting Revit Model in Navisworks (fbx)
As you can see, in the dialog box I choose meters in the convert units option. But when I import the fbx model in Infraworks (the same fbx that I imported in Civil 3D and worked ok) I am not able to see it. If I see the model options, the roof height is 40.016m when it is actualy 12.2meters, if I divide this to values it result 3.28 (factor conversion between feet and meters). With this I conclude that Infraworks is considerating that the building model is in feet, and I don't know why if Civil 3D imported correctly.
Please, help me to solve this, if not please call again @wpagl452 or someone who want to solve this problem. It's being long time ago since wrote my issues and still have the same problem. It's a shame.
