Fusion Team, Data, & Project Management
Need help managing your Fusion (formerly Fusion 360) Team Hub? Have questions about adding or removing team members, or permissions? Get help from the collaboration experts.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Some Teammates Unable to Access Project folders after Update
1 REPLY 1
eevidyut
256 Views, 1 Reply
My Fusion teammate is getting an Issue where he is unable to access project folders in the Fusion Software. Please see screenshot for reference. However, nothing changes even after 48hrs into the problem. I have tried re-login, clear cache, restart, everything. His fusion version is 2.0.8609.
Also, the teammate with the problem was able to access the files until 2 days ago (apparently when there was an auto-update which problems start). Interestingly, the other teammates on same version of fusion are able to see the folders without any problem.
Labels (3)
1 REPLY 1
lance.carocci
in reply to: eevidyut
@eevidyut could your colleague please collect application logs for us to review? This may point us in the right direction.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Additionally, within that same Help menu is the option to clear Fusion 360's cache - this is also worth a try.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Technology Administrators
