Using the thermal cooling simulation tool, I found that air particle traces pass through a solid aluminum enclosure , modeled around the internal device volume (see cross-section below). As a result, air flow is marginally exiting enclosure through designated venting holes.
Steps tried to fix the problem without success:
- Components intersections were fixed
- Simulation accuracy was set from medium to highest
