Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Thermal Study - Cooling for electronic devices
0 REPLIES 0
Message 1 of 1
sta.schaefer
72 Views, 0 Replies
Using the thermal cooling simulation tool, I found that air particle traces pass through a solid aluminum enclosure , modeled around the internal device volume (see cross-section below). As a result, air flow is marginally exiting enclosure through designated venting holes.
Steps tried to fix the problem without success:
  • Components intersections were fixed
  • Simulation accuracy was set from medium to highest
0 REPLIES 0
Technology Administrators
