Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Rectangular pattern on a piece that should change size
1 REPLY 1
maxime.etchenou
165 Views, 1 Reply
Hello I'm working on a cabinet which is not a rectangle shape, I thought I'd had dividers using the rectangular pattern to divide my piece by a number. It works fine but I'm trying to find a way for the piece to be the correct size since it has to become bigger and bigger.
Thanks a lot for the time you'll spend reading this.
1 REPLY 1
please avoid double post
günther
Technology Administrators
