Rectangular pattern while fitting a bigger space
maxime.etchenou
maxime.etchenou
Hello I'm working on a cabinet which is not a rectangle shape, I thought I'd had dividers using the rectangular pattern to divide my piece by a number. It works fine but I'm trying to find a way for the piece to be the correct size since it has to become bigger and bigger.
Thanks a lot in advance.
Need to fill the gap since the cabinet is getting largerNeed to fill the gap since the cabinet is getting larger
g-andresen
try it this way
günther
maxime.etchenou
Thanks a lot for your quick answer @g-andresen
but if I'm correct in the file you provided the shape is a rectangle, I have no issues by making a splitter in a shape that's a rectangle my issue resides in the size of a splitter when the shape makes it so I need to have a wider splitter.
g-andresen
Please post a picture showing the profil of such an object and tell us in which direction the dividers should run.
günther
g-andresen
maybe you´re looking for somethings like this?
günther
maxime.etchenou
Thank you so much.
