Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Project folders not showing
3 REPLIES 3
d_starmer
703 Views, 3 Replies
When I open Fusion 360 I can see all my project files in the data panel.  After a few seconds, the panel slides to the left and I only see the contents of one of my folders.  I run Fusion on three different computers and everything works perfectly on those two.  The only difference that I can see is that the menu bar at the top of the data panel (see below) is missing:
I've tried everything that I have read related to this topic, such as uninstalling and reinstalling, clearing my cache, deleting the LoginState.xml, renaming .dat files.  Everything that I could find.
I'm running this on a Win 10 Pro machine with all current updates.
Any suggestions?
Darren
3 REPLIES 3
tallisb
in reply to: d_starmer
Hello Darren-
Have you tried going to the File menu, then select View-->Reset to Default Layout.  Then restart Fusion 360.
I would also check to see if you are pointing to the correct "team hub".  Either you are pointing to a team hub or a personal hub.  You can check this by clicking in the upper-left of the data panel and it will show you what "hub" you are pointing to.
Brad
Brad Tallis
Fusion 360 Technical Specialist
d_starmer
in reply to: tallisb
Thanks for the suggestions Brad - unfortunately, the problem remains.
This is from the computer in which I can navigate back to my home view.  Note that the navigation bar is missing in the image above.
I'm not a member of any teams, not have I shared any of my folders or files with anyone.
tallisb
Darren-
Please send me an email to brad.tallis@autodesk.com.
After that, I will set up a shared session with you so we can troubleshoot the issue.
Brad
Brad Tallis
