Fusion Support
Generative design results missing
3 REPLIES 3
matthewcannonMFWWJ
333 Views, 3 Replies
Hello, I'm using the generative design algorithm to design a part. Initially it was working fine, but lately when I run the generate command the results are missing. I can go to the explore pane and see that 15 designs were generated from two studies, but none of them are visible (photo attached). It behaves as though I have some of the results filtered, however none of the filters are in place. Any help is appreciated,
Matt
Tags (1)
Labels (2)
3 REPLIES 3
Just bumping this. I deleted these two studies and re-ran another with the same issue.
Bumping this again
Bumping this up again.
