Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Generative design results missing
3 REPLIES 3
matthewcannonMFWWJ
320 Views, 3 Replies
Hello, I'm using the generative design algorithm to design a part. Initially it was working fine, but lately when I run the generate command the results are missing. I can go to the explore pane and see that 15 designs were generated from two studies, but none of them are visible (photo attached). It behaves as though I have some of the results filtered, however none of the filters are in place. Any help is appreciated,
Matt
Tags (1)
Labels (2)
3 REPLIES 3
Just bumping this. I deleted these two studies and re-ran another with the same issue.
Bumping this again
Bumping this up again.
Technology Administrators
