I'm not sure when this happened but I didn't have this extreme lag a few months ago the last time I used fusion for a school project. Now that I need to make another one I have this big issue. This happens even outside screencast. any Panning or sketching is just pure lag. Moving components with joints is also somewhat laggy but not to the extent of drawing lines which is weird.Things I have done to try and remedy the issue are all the optimization tips that have been given minimizing all the effects , I have tried running in DX9 and DX11, I have followed the guides to do a complete clean uninstall of fusion 360 and reinstalling. Yes all my drivers are up to date , Yes I have my windows 10 updated to the latest version. this happens even if 3D sketch is turned off.
PC Specs:
Ryzen 5 2600
16GB ram at 2600mhz
Palit 1060 3GB
Fusion is installed onto my boot drive which is an SSD
I hope someone can solve my issue as this really hampers my productivity, Thank you!
Solved by g-andresen. Go to Solution.
give this a try:
1. create a new user account (WIN / MAC) on your system
2. install Fusion and start with the known Fusion account.
good luck
günther
Thanks I didn't do as you say but It did steer me in the right direction can't believe I didn't think of it sooner I just ran the program as administrator and also in compatibility mode Somehow it worked! But what I dont understand is what was making it do that in the first place.
