Project folders not showing
d_starmer
d_starmer
When I open Fusion 360 I can see all my project files in the data panel.  After a few seconds, the panel slides to the left and I only see the contents of one of my folders.  I run Fusion on three different computers and everything works perfectly on those two.  The only difference that I can see is that the menu bar at the top of the data panel (see below) is missing:
I've tried everything that I have read related to this topic, such as uninstalling and reinstalling, clearing my cache, deleting the LoginState.xml, renaming .dat files.  Everything that I could find.
I'm running this on a Win 10 Pro machine with all current updates.
Any suggestions?
Darren
tallisb
Hello Darren-
Have you tried going to the File menu, then select View-->Reset to Default Layout.  Then restart Fusion 360.
I would also check to see if you are pointing to the correct "team hub".  Either you are pointing to a team hub or a personal hub.  You can check this by clicking in the upper-left of the data panel and it will show you what "hub" you are pointing to.
Brad
Brad Tallis
Fusion 360 Technical Specialist
d_starmer
Thanks for the suggestions Brad - unfortunately, the problem remains.
This is from the computer in which I can navigate back to my home view.  Note that the navigation bar is missing in the image above.
I'm not a member of any teams, not have I shared any of my folders or files with anyone.
tallisb
Darren-
Please send me an email to brad.tallis@autodesk.com.
After that, I will set up a shared session with you so we can troubleshoot the issue.
Brad
Brad Tallis
