I am trying to turn a long shaft that has to Keyway slots in it. My goal is to turn part of the shaft, grab it with the subspindle, Pull it out, Turn more of the shaft and cut the Keyway still using both spindles. Pull the shaft out for a second Time, Finish turning the shaft and cut the second Keyway.
It seems i am not have any trouble until i go to do the second pull. This is the alarm i get when i go to Post.
I dont need/want a subspindle Grab at this point, I only need the Main Spindle to unclamp, The sub spindle to move in the postive Direction x.xxx amount and reclamp the Main. How do i achive this?
Information: Configuration: Doosan Mill/Turn with Fanuc 0i/31i control
Information: Vendor: Doosan
Information: Posting intermediate data to 'C:\Users\RandallTutterrow\Documents\Fusion 360\NC Programs\50.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, May 24, 2023 7:29:08 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5946.0
Configuration path: C:/Users/RandallTutterrow/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/doosan mill-turn fanuc.cps
Include paths: C:/Users/RandallTutterrow/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts
Configuration modification date: Tuesday, April 4, 2023 1:22:47 PM
Output path: C:\Users\RandallTutterrow\Documents\Fusion 360\NC Programs\50.nc
Checksum of intermediate NC data: 8cc0db6fa334319b4dcc1b66c97d8003
Checksum of configuration: 9591f1ad4e52a2e3c0811337b845f57c
Vendor url: https://www.doosanmachinetools.com
Legal: Copyright (C) 2012-2023 by Autodesk, Inc.
Warning: Multiple work offsets used in program.
Generated by: Fusion 360 CAM 2.0.16009
Error: A spindle start block cannot be output while the spindles are synchronized.
Error at line: 3945
Error in operation: 'Profile Finishing 2'
Failed while processing onSection() for record 2421.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, May 24, 2023 7:29:08 PM
Post processing failed.
