Fusion Support
I don't have add-ins scripts in my fusion 360, what should I do?
8 REPLIES 8
Message 1 of 9
325 Views, 8 Replies
8 REPLIES 8
Message 2 of 9
jhackney1972
I see the icon is missing, what do you see if you select the dropdown arrow?  If still having the issue, you may want to place your mouse cursor overtop the menu, right click, and select one or both of the options.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 9
jhackney1972
Also, with your cursor over the main design window, press "S" on your keyboard.  In the search for command dialog, start typing "Scripts and Add-Ins" and select it from the list that appears.
John Hackney
Retired
Message 4 of 9
in reply to: jhackney1972
Hi  ,
I tried both options that you suggested, but I still have the problem.
Message 5 of 9
jhackney1972
You did not say what you see if you select the drop-down arrow.  You also did not say what you get if you try the process in my second post.
John Hackney
Retired
Message 6 of 9
John,
My apologies, this is what I get both options;
Option 1:
Option 2:
Message 7 of 9
John,
When I click the right in the mouse and try to reset the menu bar, there is no result at all.
Message 8 of 9
jhackney1972
If you have closed Fusion 360, re-started your computer, and restarted Fusion 360 and it is still not there it would seem you have a bad installation.  If you decide to un-install and re-install the application make sure your use the Clean Uninstall process.
There is an automatic Clean Uninstall process but I think the one listed is better, takes more time but...  You have not said what operating system you are using but if Windows, make sure you reinstall using an administrator account, turn off UAC (User Access Control) and Anti-Virus during installation.  If using a MAC, use all equalivant settings.
John Hackney
Retired
Message 9 of 9
Thanks John
Technology Administrators
