I see the icon is missing, what do you see if you select the dropdown arrow? If still having the issue, you may want to place your mouse cursor overtop the menu, right click, and select one or both of the options.
John Hackney, Retired
Also, with your cursor over the main design window, press "S" on your keyboard. In the search for command dialog, start typing "Scripts and Add-Ins" and select it from the list that appears.
You did not say what you see if you select the drop-down arrow. You also did not say what you get if you try the process in my second post.
John,
When I click the right in the mouse and try to reset the menu bar, there is no result at all.
If you have closed Fusion 360, re-started your computer, and restarted Fusion 360 and it is still not there it would seem you have a bad installation. If you decide to un-install and re-install the application make sure your use the Clean Uninstall process.
There is an automatic Clean Uninstall process but I think the one listed is better, takes more time but... You have not said what operating system you are using but if Windows, make sure you reinstall using an administrator account, turn off UAC (User Access Control) and Anti-Virus during installation. If using a MAC, use all equalivant settings.
