Can’t insert an SVG file. I select insert svg. It allows me to click on INSERT FROM MY COMPUTER. Then it just stops. It used to let me select a folder and the SVG file. Now it just closes that window and nothing happens. I have been able to insert from my computer in the past. Now when I select INSERT FROM MY COMPUTER nothing happens. Something has changed and I'm not sure what. I am able to upload an SVG into one of my project folders and then select it, but I can’t simply hit "INSERT FROM MY COMPUTER" anymore.
Try closing Fusion and reopening it. If that does not work, visit the Fusion Service Utility and try the Repair option.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
There is a very old bug where if the last directory you saved\opened a file from is no longer available you don't get the windows open\save dialog. See this post for a workaround.
Mark Hughes
Owner, Hughes Tooling
Thanks, but restarting didn't help. When I ran the repair tool, I get a system error that a .dll is missing. So I uninstalled and reinstalled Fusion. Error goes away but still can't insert SVG. I select insert svg. It allows me to click on INSERT FROM MY COMPUTER. Then it just stops. It used to let me select a folder and the SVG file. Now it just closes that window and nothing happens. Something has changed. I am able to upload an SVG into one of my project folders and then select it, but I can’t simply hit INSERT FROM MY COMPUTER anymore. These are extra steps I shouldn’t have to do. Something isn’t right. Tried exporting the file from Fusion, and defining a new location, then retrying the insert from my computer option and no change.
