As you can tell by looking the distance between these values is not the same, even though they are both showing 1/64":
I would assume it is because of the scale I am working at, and the precision setting. But I'm not sure what setting will fix this. These are my settings:
Would love some guidance, thanks!
Solved by glencandle. Go to Solution.
Update: I thought maybe it was because I was using fractional in my display format so I changed it to decibel, restarted Fusion (just in case, as that seems to kick 'bugs' to the curb sometimes) and I'm still getting the error:
Am I being very dumb or is this a bug??
Please attach the model this problem is occurring in.
John Hackney, Retired
Hey John, I figured it out right as your reply came in.
It was a glitch. I simply deleted both driven values and created them again and the dimensions came out right this time.
Cheers.
