As you can tell by looking the distance between these values is not the same, even though they are both showing 1/64":
I would assume it is because of the scale I am working at, and the precision setting. But I'm not sure what setting will fix this. These are my settings:
Would love some guidance, thanks!
Solved by glencandle. Go to Solution.
Update: I thought maybe it was because I was using fractional in my display format so I changed it to decibel, restarted Fusion (just in case, as that seems to kick 'bugs' to the curb sometimes) and I'm still getting the error:
Am I being very dumb or is this a bug??
Please attach the model this problem is occurring in.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Hey John, I figured it out right as your reply came in.
It was a glitch. I simply deleted both driven values and created them again and the dimensions came out right this time.
Cheers.
