Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Driven Dimensions Showing Wrong Values
3 REPLIES 3
glencandle
207 Views, 3 Replies
As you can tell by looking the distance between these values is not the same, even though they are both showing 1/64":
I would assume it is because of the scale I am working at, and the precision setting.  But I'm not sure what setting will fix this. These are my settings:
Would love some guidance, thanks!
3 REPLIES 3
glencandle
in reply to: glencandle
Update: I thought maybe it was because I was using fractional in my display format so I changed it to decibel, restarted Fusion (just in case, as that seems to kick 'bugs' to the curb sometimes) and I'm still getting the error:
Am I being very dumb or is this a bug??
jhackney1972
Please attach the model this problem is occurring in.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
glencandle
in reply to: jhackney1972
Hey John, I figured it out right as your reply came in.
It was a glitch.  I simply deleted both driven values and created them again and the dimensions came out right this time.
Cheers.
Technology Administrators
