Fusion Support
Can't log into Fusion 360
10 REPLIES 10
Message 1 of 11
Max_Lechwar126
722 Views, 10 Replies
Hello, this is my first time installing the Fusion 360 Application on my X64 Windows 11 Pro computer.
Everytime I try to log in via the application, it just puts me back onto the enter email screen. I tried a few fixes like renaming the NMachineSpecificOptions.xml file and deleting the LoginState.xml file however none of these fixes worked.
One time I saw this error message, however I havent received it again. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-when-trying-...
Any help would be appreciate thanks as I really need this for school.
10 REPLIES 10
Message 2 of 11
@Max_Lechwar126 Canyon please use your credentials and login to https://login.autodesk360.com/login. If you can login successfully now can you try to use Fusion 360?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
Hello, this is what I get when logging into my account from that link. I am receiving no emails about receiving an autodesk ID or anything. I also checked the spam folder. And the resend invite button does nothing.
Message 4 of 11
@Max_Lechwar126 I am asking our engineering team to look into the account. I will post back here as soon as I know more.
Autodesk Fusion
Join Fusion Insider
Message 5 of 11
Any updates on the situation? I still cannot log in.
Message 6 of 11
@Max_Lechwar126 I have logged a ticket internally to look into this account. Let me see the update on it.
Autodesk Fusion
Join Fusion Insider
Message 7 of 11
Same here.  12 hours and still no go.
Message 8 of 11
any updates now?
Message 9 of 11
@Max_Lechwar126 Apologies for the delay. I have tagged our engineering team directly to this thread.
Autodesk Fusion
Join Fusion Insider
Message 10 of 11
Hi @Max_Lechwar126
Could you please check your email for any Invites which mentions to join the HUB?
If you have received it, can you click on the link to join the HUB and register in Fusion?
And If you haven't received the Invite, or the earlier received Invite Link has expired, could you ask Chris Congdon (chris.congdon456@schools.sa.edu.au) who is the admin of your HUB to ReSend Invite?
Resend Invite is available under Sent Invitation in Admin Panel on https://login.autodesk360.com/login
Once you receive the invite on your Mail Id, try to join through the Invite link on MAIL.
Message 11 of 11
I got my teacher to resend an invite, and I also fully reinstalled the program. That has fixed my issue.
Thank you very much for the help 🙂
Technology Administrators
