- Mute
- Permalink
- Report
Fusion 360 free version.
My project is to make an audio diffusor
So, I know the size of the whole frame.
The frame is divided in a grid-block 3x3cm
Each block should be extruded separately because it has a different height than the adjacent ones.
Here below an example, where I extruded the first 3 block-lines (one-by-one).
Now my question is: by using parametric method, is it possible to import a CSV that contains the extrusion of each block and automate this process and expedite it?
Here the values I would turn into a CSV.
