Fusion crashes when creating toolpath for additive manufacturing.
slipperysubs
slipperysubs
While generating the toolpath for this linked model Fusion crashes and is completely gone before I can even submit a report. I captured the attached video to see that message flash by just before disappearing.
https://a360.co/4fvwfkY
serge.quiblier
Hello @slipperysubs
I tried to slice and generate the gcode from your file.
When opening the file, and switching to the Manufacture workspace, a toast notification appeared.
But it did not prevent me generating the toolpath.
Then I posted the gcode without problem either.
My config:
Fusion 2.0.20508 x86_64
running Window 10.
Regenerating the toolpath seems to stall at two third, but it reach the end. No crazy CPU or memory usage.
The resulting gcode is 142Mb.
Apparently the model is Ok. Possibly a Mac-specific issue.
I will inform the developers, and let them investigate.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
