Repetitive extrusions for audio-diffusor: is it possible to use a CSV to automate it?
tormy.vancool
tormy.vancool
Fusion 360 free version.
My project is to make an audio diffusor
So, I know the size of the whole frame.
The frame is divided in a grid-block 3x3cm
Each block should be extruded separately because it has a different height than the adjacent ones.
Here below an example, where I extruded the first 3 block-lines (one-by-one).
Now my question is: by using parametric method, is it possible to import a CSV that contains the extrusion of each block and automate this process and expedite it?
Here the values I would turn into a CSV.
TrippyLighting
There is no out-of-the-box tool available for this through Fusion menus.
If you are familiar with Python programming, this can possibly be done through Fusions Python AP
tormy.vancool
Uhm no. I'm not familiar with Python programming
JeromeBriot
JeromeBriot
@tormy.vancool
I wrote a Python script that automatically reads the CSV file and generates the corresponding design (less than a minute on my machine). Let me know if you're still interested.
tormy.vancool
Ah that's really great.
