installation problem fusion
topo89888
Message 1 of 22
topo89888
please help, unknown error when installing fusion
Replies (21)
Message 2 of 22
RajkumarIlanchelian
@topo89888 Please try the below.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 22
topo89888
can you please tell me how to go to % localappdata %\Autodesk\?
Message 4 of 22
topo89888
I think I deleted all the folders you indicated and did all the above steps, unfortunately it didn't help
Message 5 of 22
RajkumarIlanchelian
@topo89888 The logs indicate that some of the requests from Fusion are not passing through.
1. Would it be possible for you to say connect to a different network like a phone hotspot and see if that moves this along?
2. Is there any windows defender or anti virus that is blocking the installer?
Autodesk Fusion
Join Fusion Insider
Message 6 of 22
topo89888
1. Connecting to another network didn't help either.
2. It seems that no, Windows Defender doesn't interfere.
Message 7 of 22
topo89888
the problem was indeed hidden in the connected network, thank you very much
Message 8 of 22
askHLJMM
Community Visitor
Community Visitor
how did you go to local app data
?? same issue here
Message 9 of 22
askHLJMM
Community Visitor
Community Visitor
how did you go? same issue here
Message 10 of 22
jhackney1972
Take a look at this Autodesk Web Page for the possible solution to your installation issue, at least according to you post screen capture.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
Message 11 of 22
goodlucktor1
Community Visitor
Community Visitor
please help,i also had an unknown error when installing fusion
Message 12 of 22
goodlucktor1
Community Visitor
Community Visitor
please help, i also had an unknown error when installing fusion
Message 13 of 22
jhackney1972
Did you try the process outlined in Message #2 of this Forum Post?
Message 14 of 22
RajkumarIlanchelian
@goodlucktor1 This should help.
Autodesk Fusion
Join Fusion Insider
Message 15 of 22
mmkika
Community Visitor
Community Visitor
I also have a problem while installing the Fusion program. Here is the log file and a screenshot of the error.
Message 16 of 22
RajkumarIlanchelian
@mmkika Likely a network certification error. Can you try the solution from this thread?
https://forums.autodesk.com/t5/installation-licensing-forum/nested-asn1-error-ssl-c-4003/m-p/9497488...
Autodesk Fusion
Join Fusion Insider
Message 17 of 22
mmkika
Community Visitor
Community Visitor
Thank you for the quick response. However, I just tried the solution from the link you sent me and it didn’t work. This time, I got error 4014.
Message 18 of 22
RajkumarIlanchelian
@mmkika one more post for you to try out - https://forums.autodesk.com/t5/fusion-support-forum/cannot-install-fusion/td-p/13197799
Which country are you accessing from?
Autodesk Fusion
Join Fusion Insider
Message 19 of 22
mmkika
Community Visitor
Community Visitor
I am from Serbia. I noticed from the links you sent me that many users from Serbia are having the same problem. I uninstalled the Celik program mentioned in the posts you shared (including the certificates that come with it), but I still have the same problem and the same error.
Message 20 of 22
mmkika
Community Visitor
Community Visitor
I uninstalled the Celik program and its certificates.
I tried the solutions from the links you sent me, but I was not successful.
I also tried what one user described as a solution:
  • Cleaning Firefox and Internet Explorer cache, cookies, and SSL certificates (I'm only using Firefox, but I cleaned both).
  • Turned off the firewalls.
  • Told Windows Defender not to check anything.
  • Finally, I used IE instead of Firefox. I downloaded it and started it with IE, so I didn’t have to rename it or run it as admin.
However, it still didn’t work! Is there any other solution?
