Cannot install Fusion
ivan_urosevi
Observer Observer
Message 1 of 11
ivan_urosevi
Observer
Observer
Hello, i downloaded installer but it won't install. I tried on 2 different pcs and on 2 virtual machines, and nothing. Log is in attachment, hope you can help me. Firewall is off, there is no antivirus installed.
This is error: ssl.SSLError: not enough data: cadata does not contain a certificate (_ssl.c:4014)
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@ivan_urosevi Can you see if the solution called out in the below thread helps ?
https://forums.autodesk.com/t5/fusion-design-validate-document/unable-to-install-fusion-360-ssl-erro...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
ivan_urosevi
Observer
Observer
No, your link in that thread is not active, and what customer said didn't help. I did all the things he did, but still the same
Ivan
Message 4 of 11
ivan_urosevi
Observer
Observer
So what i did. I turned off all apps which start with windows, turned off firewall, turned off windows defender, clear SSL in Internet options, reset internet options to default, clear cache, clear temp, PC is on LAN, not on wi fi. What else to do?
Message 5 of 11
RajkumarIlanchelian
@ivan_urosevi Checking with our installer team.
Autodesk Fusion
Join Fusion Insider
Message 6 of 11
RajkumarIlanchelian
@ivan_urosevi Is it possible you can try with another network if possible , say a mobile hotspot, maybe? Also which country are you located? We have seen (rarely) some install related issues based on the location which may need some looking into with logs etc.
Autodesk Fusion
Join Fusion Insider
Message 7 of 11
ivan_urosevi
Observer
Observer
It's not problem with internet, or my location (I am from Serbia, btw), since i managed to install it on clean windows installed on virtual machine. But the problem is that i must install it on lap top which is connected to my machine, and i cannot format it, since i have many different software there. I tried to install on 3 different pcs, which already have many certificates installed, and it only worked in 4th, virtual machine. So something else is blocking installation, i assume some other certificate, but how to discover which one?
Message 8 of 11
RajkumarIlanchelian
Message 9 of 11
ivan_urosevi
Observer
Observer
No, i removed Celik as it was mentioned in this post, and all it's certificates from windows, bur still same error...
Message 10 of 11
djherceg
Community Visitor
Community Visitor
Uninstall the Celik software (Citac Elektronske Licne Karte). This software installs some certificates which mess up validation during the install process of Fusion 360.
[Update] Ok, I just noticed that this remedy doesn't work for you. It worked for me, though.
Message 11 of 11
bojans96
Observer
Observer
This worked for me! I got two separate errors until I uninstalled the Celik app. Thanks!
