Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi im trying to install Fusion 360 on Windows 10 home edition
and i get this error when i start the installation nested asn1 error (_ssl.c:4003)
here's a log
2020-05-04 17:56:54,750 - MainProcess(15024) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-05-04 17:56:54,751 - MainProcess(15024) - MainThread - adsk.dls.streamer - INFO :: # #
2020-05-04 17:56:54,751 - MainProcess(15024) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001B000E04DC8> #
2020-05-04 17:56:54,751 - MainProcess(15024) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-05-04 17:56:54,751 - MainProcess(15024) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\milan\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2020-05-04 17:56:54,753 - MainProcess(15024) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\milan\AppData\Local\Temp\7zS7D17.tmp\resources\buildinfo.json
2020-05-04 17:56:54,754 - MainProcess(15024) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'reconfigure', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'write_through', 'writelines']
2020-05-04 17:56:54,755 - MainProcess(15024) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-05-04 17:56:54,755 - MainProcess(15024) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20200423154600
2020-05-04 17:56:54,755 - MainProcess(15024) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2020-05-04 17:56:54,756 - MainProcess(15024) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\milan\AppData\Local\Temp\7zS7D17.tmp\resources
2020-05-04 17:56:54,756 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2020-05-04 17:56:54,757 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000001B000E63DC8>, pipes=None, procfac=<function deploy_process at 0x000001B000EED1F8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-05-04 17:56:54,758 - MainProcess(15024) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2020-05-04 17:56:54,760 - MainProcess(15024) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2020-05-04 17:56:56,001 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2020-05-04 17:56:56,035 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2020-05-04 17:56:56,035 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2020-05-04 17:56:56,212 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: The host autodesk.com is accessible
2020-05-04 17:56:56,223 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMjEuMTg5LjExMw==
2020-05-04 17:56:56,224 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTkyLjE2OC4xLjc=
2020-05-04 17:56:57,412 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgY3NwMS56dGUuY29tLmNuDSwgQWRkcmVzczogIDE5Mi4xNjguMS4xDQ==
2020-05-04 17:56:57,412 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2020-05-04 17:56:57,412 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\Streamer\src\adsk\dls\streamer\process.py", line 1543, in execute
File "R:\Streamer\src\adsk\dls\streamer\process.py", line 1447, in execute_without_errorhandling
File "R:\Streamer\src\adsk\dls\streamer\process.py", line 1398, in _get_default_app_streamer
File "R:\Streamer\src\adsk\dls\streamer\process.py", line 589, in primary_app_network_manifest
File "R:\Streamer\src\adsk\dls\streamer\process.py", line 852, in _load_appmanifest
File "R:\Streamer\src\adsk\dls\streamer\factory.py", line 268, in app_manifest
File "R:\Streamer\src\adsk\dls\streamer\factory.py", line 93, in _ResilientUrlOpen
File "R:\Streamer\src\adsk\dls\streamer\netlib.py", line 407, in get_httpshandlergen
File "C:\3P\PYTHON\3.7.6\WIN64_1\lib\ssl.py", line 589, in create_default_context
File "C:\3P\PYTHON\3.7.6\WIN64_1\lib\ssl.py", line 490, in load_default_certs
File "C:\3P\PYTHON\3.7.6\WIN64_1\lib\ssl.py", line 482, in _load_windows_store_certs
ssl.SSLError: nested asn1 error (_ssl.c:4003)
2020-05-04 17:57:30,885 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2020-05-04 17:57:30,886 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.process - WARNING :: Exception in Deploy nested asn1 error (_ssl.c:4003)
2020-05-04 17:57:30,930 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2020-05-04 17:57:30,947 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2020-05-04 17:57:30,947 - MainProcess(15024) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer - INFO :: # #
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000253D71E3D48> #
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\milan\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\milan\AppData\Local\Temp\7zSA991.tmp\resources\buildinfo.json
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'reconfigure', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'write_through', 'writelines']
2020-05-04 17:58:10,558 - MainProcess(12964) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20200423154600
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\milan\AppData\Local\Temp\7zSA991.tmp\resources
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x00000253D7113DC8>, pipes=None, procfac=<function deploy_process at 0x00000253D71DC1F8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2020-05-04 17:58:10,568 - MainProcess(12964) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2020-05-04 17:58:10,878 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2020-05-04 17:58:10,878 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2020-05-04 17:58:10,878 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2020-05-04 17:58:11,028 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: The host autodesk.com is accessible
2020-05-04 17:58:11,028 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMjEuMTg5LjExMw==
2020-05-04 17:58:11,028 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTkyLjE2OC4xLjc=
2020-05-04 17:58:12,218 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgY3NwMy56dGUuY29tLmNuDSwgQWRkcmVzczogIDE5Mi4xNjguMS4xDQ==
2020-05-04 17:58:12,218 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2020-05-04 17:58:12,218 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - ERROR :: Exception during processing:
2020-05-04 18:01:34,698 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2020-05-04 18:01:34,698 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.process - WARNING :: Exception in Deploy nested asn1 error (_ssl.c:4003)
2020-05-04 18:01:34,735 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2020-05-04 18:01:34,758 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2020-05-04 18:01:34,758 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2020-05-04 18:01:34,758 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2020-05-04 18:01:34,758 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000253D71E3D48> #
2020-05-04 18:01:34,758 - MainProcess(12964) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2020-05-04 18:05:26,021 - MainProcess(6500) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-05-04 18:05:26,022 - MainProcess(6500) - MainThread - adsk.dls.streamer - INFO :: # #
2020-05-04 18:05:26,022 - MainProcess(6500) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002B857EE4D88> #
2020-05-04 18:05:26,022 - MainProcess(6500) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-05-04 18:05:26,022 - MainProcess(6500) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\milan\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2020-05-04 18:05:26,022 - MainProcess(6500) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\milan\AppData\Local\Temp\7zS4FA7.tmp\resources\buildinfo.json
2020-05-04 18:05:26,023 - MainProcess(6500) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'reconfigure', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'write_through', 'writelines']
2020-05-04 18:05:26,024 - MainProcess(6500) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-05-04 18:05:26,024 - MainProcess(6500) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20200423154600
2020-05-04 18:05:26,024 - MainProcess(6500) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2020-05-04 18:05:26,024 - MainProcess(6500) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\milan\AppData\Local\Temp\7zS4FA7.tmp\resources
2020-05-04 18:05:26,026 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2020-05-04 18:05:26,027 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000002B857F83DC8>, pipes=None, procfac=<function deploy_process at 0x000002B85808E1F8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5)
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-05-04 18:05:26,028 - MainProcess(6500) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2020-05-04 18:05:26,029 - MainProcess(6500) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2020-05-04 18:05:26,257 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2020-05-04 18:05:26,258 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2020-05-04 18:05:26,258 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2020-05-04 18:05:26,416 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: The host autodesk.com is accessible
2020-05-04 18:05:26,426 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: NTAuMTkuMTQ5LjQ=
2020-05-04 18:05:26,426 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTkyLjE2OC4xLjc=
2020-05-04 18:05:28,131 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgY3NwMS56dGUuY29tLmNuDSwgQWRkcmVzczogIDE5Mi4xNjguMS4xDQ==
2020-05-04 18:05:28,131 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled False
2020-05-04 18:05:28,132 - MainProcess(6500) - InstallDriver - adsk.dls.streamer.process - ERROR :: Exception during processing:
