How to add text in new autodesk fusion 360 - also can you still download legacy?
Message 1 of 26
How do you add text in new autodesk fusion 360?
Can you still download legacy? I knew how to do this in legacy.
Accepted solutions (4)
Replies (25)
Message 21 of 26
TheCADWhisperer
This is an imported Mesh Body, not a solid body.
You could convert it to a solid body, but with geometry this simple - I recommend that you recreate it from scratch using only Fusion 360 (no import of stl).
See Attached start...
Message 22 of 26
jhackney1972
I agree with @TheCADWhisperer, use his supplied model and keep the STL out of this project.  I took his supplied box and added the text bodies to it so it is now only one body.  I must emphasis some of the text, particularly the "As" have some issues.  I could not identify the font so I did not modify the text at all, just combined it with the model supplied by @TheCADWhisperer .  It is attached.
By the way, it is not a good idea to "piggyback" your forum question on top of an old forum post.  It just gets lost in the shuffle and does not get the needed attention.  Create you own post next time you have a question, they do not cost anything.
John Hackney, Retired
Message 23 of 26
adamthomas10
Observer
Observer
@TheCADWhisperer @jhackney1972 thank you very much, really appreciate it. I'm new to it all slowly but surely getting the hang of everything there's a lot to learn haha...
Message 24 of 26
brizzy1951
Observer
Observer
Thanks that solved my problem
Kind Regards, Denis
Message 25 of 26
wowtester
Community Visitor
Community Visitor
I have tried this several times and I just get "cannot complete extrusion".
Message 26 of 26
g-andresen
please start a new topic and share a sample file
File > export > save as f3d on local drive  > attach to post
günther
