Split control curve in sketch
avaviel
avaviel
Is there a way to split a control curve in Fusion, similar to how you can in illustrator? In illustrator you can hold down alt and manipulate the control lines separately, resulting in sharp transitions.
The uploaded image is from illustrator.
g-andresen
A real sharp-edged tangent point is not possible in Fusion. The effect can be achieved by connecting 2 splines without tangential constraint.
Günther
jeff_strater
@avaviel - you can use the Break Curve command in sketch to create a sharp break in a curve.  The screencast below is for Fit Point splines, but the same technique works for Control Vertex splines:
Jeff Strater
Engineering Director
