I have no ability to edit or create sketches
Message 1 of 9
My app just updated today to the new ui and I go to click create a sketch and I don’t  see a set of sketch tools as all the videos showed online also I’m using Mac OS X
Replies (8)
Message 2 of 9
wmhazzard
Click on create sketch, click on a plane and all of the tools are at the top of the screen.
Message 3 of 9
g-andresen
Look at the gif in This thread   (2/5)
Günther
Message 4 of 9
no does not switch to that when I do that I do not see that after I select create a sketch select my plane and that bar does not show
Message 5 of 9
Message 6 of 9
g-andresen
rightclick toolbar > reset toolbar customization
Message 7 of 9
davebYYPCU
Wow, That pic is worth a 1000 words,
Dead in the Water,
at least not on my windows 10 for the time being,
@jeff_strater@ryan.bales and or @Phil.E would need the file, and description of the hardware you are running, maybe even the Diagnostic log file.
Message 8 of 9
I did have it working a few times today but after saving my project and closing the program out went to edit my project and nope not working
Message 9 of 9
ryan.bales
Autodesk Support
Autodesk Support
So it looks like the contextual menus are missing like finish sketch. I'm guessing you either have an underlying graphics issue or the install is broken and needs reinstalled using the cleanup tool.
If you need to reinstall:https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Check your graphics and driver too - use dxdiag.exe in windows and use the display tab.
Ryan Bales
Fusion 360 Product Support
