Fusion 360 won't create modelled threads of some sizes
dkorchagin
Message 1 of 49
dkorchagin
What I noticed is when you try to model a thread using thread tool it fails to generate its helix path when you choose any size less than 6mm, and with 6mm and above it can only succeed with certain designation (for example it works fine with 6x1.0 but fails to generate 6x0.8). Is this a limitation or a bug?
Replies (48)
Message 41 of 49
I get the same problem VERY often, only options are: 0.0118", 1", 2", 3" and 4" are the only ones that appear.
(my previous post in this thread seems to have disappered).
Message 42 of 49
Ok, now the "make thread" tool will not work with ANY "ANSI Threads". (exept 0.0118, 1, 2, 3, 4 inch)
No matter what I try; clear user cache, use uninstall cleaner program and reinstall.
Nothing, whatsoever.
Then all of a sudden, it works, some of them, not all different pitches.
Seems if you chose the hole first, then the thread tool, it is more likly to give an error.
Directly after that, it stopped working again.
Is the model to complex?
Message 43 of 49
paul.clauss
Hi @Anonymous
Thanks for posting. Our development team is still investigating this issue and I've still been unable to recreate it on my system. Would you mind sharing:
  1. A screencast illustrating the behavior on your end - please show how you are unable to create threads.
  2. Your diagnostic log files.
This information may help us learn more about this behavior and work toward a solution - we appreciate you reaching out.
Paul Clauss
Product Support Specialist
Message 44 of 49
Here are my Diagnostic logs.
If I just start Fusion 360, the thread tool has all the options for "ANSI Unified Screw Threads".
But as soon as I load the saved model, only 0.0118", 1", 2", 3" and 4" are available.
The model have both "ANSI Unified Screw Threads" and "ISO Metric profile" threads.
Message 45 of 49
paul.clauss
Hi @Anonymous
Thanks! Would you mind sharing the problem model with me? I'm happy to have a look.
Paul Clauss
Message 46 of 49
Strange, I had no option for archive (.f3d)
Message 47 of 49
paul.clauss
Hi @Anonymous
Thanks for posting. I had no problems with applying threads in the file you attached.applythreads.gif
Does the original file contain inserted/linked components? If so, you'd need to share a downloadable link of the Fusion design - please do so if you continue to see problems.
Paul Clauss
Message 48 of 49
Hope this works.
https://a360.co/2L4qMa6
Message 49 of 49
paul.clauss
Hi @Anonymous
Thanks for sending the file over. I found that I was again able to create any size of modeled thread in the file, but have passed it along to our development team for further investigation. We appreciate your input on this issue and I'll keep you updated with any new information on this thread.
Paul Clauss
