Constrain Components feature missing from Assemble - v.2603.0.86
pmusselmanJLVUJ
Message 1 of 22
pmusselmanJLVUJ
Am I missing something? I can't access the new Constrain Components feature in either the toolbar or search menu.
Replies (21)
Message 2 of 22
-KyleWilliams-
Are you able to reset your cache in Fusion and see if that helps?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-clear-local...
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
Message 3 of 22
swapnil.hamdapureDDSVZ
Hi @pmusselmanJLVUJ Can you please share the logs? Then try to clear the cache as suggested by @-KyleWilliams-
Message 4 of 22
sibashis.bishi
Hi @pmusselmanJLVUJ
Sorry to hear that you are not able to access the new Constrain Components feature. Can you kindly do a Network Diagnostic Test at your end from Fusion Service Utility and make sure all test is green. It will take a min to do the test.
You can access Network Diagnostic Test from the Fusion Service Utility : Fusion Service Utility Link
More details on how to do the Network Diagnostic Test : Network Diagnostic Test Link
Sibashis Bishi
Senior Software Engineer
Autodesk, Inc.
Message 5 of 22
pmusselmanJLVUJ
Thanks for the quick reply everyone. Logs attached.
No change after clearing the cache.
Message 6 of 22
pmusselmanJLVUJ
All green on the network diagnostic test.
Message 7 of 22
g-andresen
take a look at this thread
günther
Message 8 of 22
sibashis.bishi
Hi @pmusselmanJLVUJ
Thank you for sharing the logs. One the important component to access Constraint Component feature is LaunchDarkly client initialization (Ports and Domains required by Fusion ). From the logs that you have shared, I can see that "LaunchDarkly client initialization process is not finished successfully!" due to network connectivity issue "FusionDiagnosticLogs\Autodesk Fusion 360\HGAJBT42KG5JWFBW\logs\AppLogFile20250714T092243.log"
Since you have mentioned "the network diagnostic test is all green", can you restart fusion.
Sibashis Bishi
Autodesk, Inc.
Message 9 of 22
pmusselmanJLVUJ
Not sure what changed, but I cleared the cache for a second time and that seems to have done it. Logs attached.
Message 10 of 22
butch_berney
I have the same problem as in the original post. The constrains feature is not showing. I have cleared the cache and restarted Fusion twice. The Service Utility is all green *except for "launchdarkly".
Any hints on what is preventing the launchdarkly service from starting?...or how to get it to start?
Message 11 of 22
sibashis.bishi
Hi @butch_berney
can you please check if your firewall or network is not blocking launch darkly access. More details: Link
Sibashis Bishi
Autodesk, Inc.
Message 12 of 22
sibashis.bishi
Hi @butch_berney
Can you please update you fusion to build 2603.1.28. You will be able to access the constrain component feature.
Sibashis Bishi
Autodesk, Inc.
Message 13 of 22
butch_berney
Hi
It looks like I am on 2603.1.15, but when I "check for updates" nothing newer shows up. I'm guessing there is a way to find the newer version but I looked around the menus and didn't see it. Can you point me in the right direction?
Thanks 🙂
Message 14 of 22
butch_berney
It's certainly possible that something is blocking that service, but I don't have access to modify firewall settings on my work computers. This is controlled by IT, and in my experience, they are not so interested in modifying the configurations...particularly for an issue that only affects a single user (or maybe a few users) out of a population of 20,000 (or so) employees. I can't say that I blame them.
Let's see if the newer build (once I find out how to access it) mentioned in your other post fixes the problem.
Message 15 of 22
sibashis.bishi
Hi @butch_berney
The latest update was rolled out couple of hours back. You must see the update option in sometime. Thank you for your patience.
Sibashis Bishi
Autodesk, Inc.
Message 16 of 22
butch_berney
It appears that the 2603.1.28 is not available yet? Or maybe I need to use a different method to find it?
If there is a way for me as a "regular" user can get the update that would be great. Otherwise, I'll just wait until it gets released.
Butch
Message 17 of 22
Hi @butch_berney Sorry for the confusion caused. The fix is not available to the production build. It's currently with the Insider build. You can access the Insider build by joining the Insider program. https://feedback.autodesk.com/key/Fusion360Insider
Message 18 of 22
butch_berney
I have looked at the details, and I'm not interested in the extra "involvement" to being an "insider". I'll wait for the fix to be released to production.
Thanks for the clarification 🙂
Message 19 of 22
Hi @butch_berney The new update is available. Can you please check at your end and let me know if its working or not?
Message 20 of 22
butch_berney
Update is installed, and the constraints appear to be active. The "launchdarkly" service is still blocked. Not sure what that affects, but at least the constraints are showing now.
Thanks for the help 🙂
