Changing the Part's Movement Direction (Edit Motion Limits)
adanbeye
adanbeye
I can move the fork-like piece on the left as desired by selecting "custom." However, when I try to do the same for the piece on the right, I select "custom" and then specify the direction line, but when I click OK, it moves in a different direction.
Am I missing something? I don't understand.
I'm attaching the assembly I want to move.
jhackney1972
This is not a job for a Slider Joint, you should be using a Pin (hole) and Slot Joint.  Also, your base plate was only a Body, not a Component, which interferes with joint process.  I converted it to a Component but due to timeline issues I could not carry the sketch into the component.  Please adjust the Joint Motion Limits to suit.  Model is attached
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
adanbeye
Mr. jhackney1972, although I did what I said, my problem continued, but your suggestion gave an idea.
Custom and selecting the direction line, not through the plate -like plate, but by cutting anywhere in the middle plate, and when I clicked on the line consisting of that cut, I determined the direction. That's how I solved my problem.
If anyone wants to examine, I share the piece in Annex.
