A component by Insert Derive goes wrong about decal
hajime2MRG3
Message 1 of 9
hajime2MRG3
source (test1):
Insert Derive command (test2):
Bug?
Replies (8)
Message 2 of 9
TrippyLighting
@Phil.E please check this out. THe decal in the derived component is still present in the browser, but it looks scrambled in the 3D viewport.
Looks like a bug to me.
Message 3 of 9
Phil.E
Perform a compute all, the decal resolves itself.
This seems like the decal/model is not being computed in graphics properly. Filed FUS-127908
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 9
hajime2MRG3
The Compute All command did nothing on my PC. (Fusion 360 version is 2.0.15995 x86_64)
Anyway I am looking forward to seeing it corrected. Thank you.
Message 5 of 9
TrippyLighting
Compute All did not do anything on my MacBook Pro either.
Message 6 of 9
jhackney1972
I know it is a silly process but if I Derive a Component, with a Decal, into an assembly, the Decal is messed up.  If I Break Link on the Derived component and then immediately Undo the Break Link the Compute All function restores the Decal in the Derived component.  Something about the toggle of Break Link and Undo to put it back into a Derived Component makes the Compute All work.
Working on Windows 10.
John Hackney, Retired
Message 7 of 9
hajime2MRG3
It works like a charm. Thank you.
Message 8 of 9
Phil.E
Play the timeline and then compute all. I left out the play-action. Something about the decal is just not getting computed correctly by the derive workflow itself.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
martongr
I have the same issue. Break link magically solves it, but in my case, if I undo it, it gets broken again.
Fusion 2.0.19941 arm64 [Native]
macOS 14.5 (23F79) on MacBookPro18,3
